RLD65MPT5 Pinout
berkay_91
Newbie level 6
Newbie level 6
Hi, ı want to driver RLD65MPT5 laser diode, and ı can not understand pinout diagram, which pin must be hook up laser driver? can you explain this laser diode's pins?
  • RLD65MPT5-ZZZ Laser Diode.pdf
Any doubts what L.D. and P.D. means?
Which laser driver are you considering?
Datasheet parameters suggest that this laser diode (L.D.) can't be safely operated without using feedback of built in photo diode (P.D.) because maximal threshold current and output power at minimal threshold overlap, you can't guarantee to keep maximum optical output (avoid breaking the laser) by only limiting current.
I want to use HV9910 LED driver IC, can you tell me which pins must be connect
--- Updated ---
https://postimg.cc/Hcf8M8c8
Berkay,
You can not use a switched mode regulator for a laser.
It must be very fast to regulate current from PD current ratio thus using a linear circuit. The PD captures a small amount of the laser which has negative resistance properties starting up "lasing" so stability from loop gain and minimal delay is important to minimize this error in regulating voltage or limiting current.
Write your reply...
LaTeX Commands Quick-Menu:
