ripple content of a standard Lithium ion battery.
allennlowaton
Full Member level 5
Full Member level 5
Taiwan
Good day EDA fellows,
I would like to ask the usual (based on experimentation) ripple content of a standard Lithium ion battery.
Thank you.
I guess, you need to explain the question. What's "ripple content"? If you are referring e.g. to ripple current, it's primarly a load related quantity.
I'm referring to the ripple voltage that's coming out from the Li-ion battery. Although, I have seen in many applications that a very large capacitor is usually used to filter out ripples but I still want to know if there's an an acceptable voltage ripple from it.
For simulation purposes, I need to assume a voltage ripple from the battery.
How do you expect a battery to produce a ripple voltage? I can hardly imagine it. Large capacitors are used e.g. in mobile phones to smooth the pulsed transmitter current towards the battery and reduce the dynamical battery impedance.
