joshy.uc@gmail.com
Newbie level 2
i have done a program in xilinx(ripple carry adder in structural modeling).
8888888888888888888888888888888888888888888888888888888888888888
full adder program was also done separately.it is as follows
but while simulating the program..,error is there as follows
but i have compiled the two programs separately.
i got the full adder program simulated output perfectly..
i am not able to trace the program..please help..
awaiting your response...
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity ripple is Port ( x : in STD_LOGIC_VECTOR (3 downto 0); y : in STD_LOGIC_VECTOR (3 downto 0); c : in STD_LOGIC; s : out STD_LOGIC_VECTOR (3 downto 0); co : out STD_LOGIC); end ripple; architecture Behavioral of ripple is component fulladd port(a,b,cin:in STD_LOGIC;cout,sum:out STD_LOGIC); end component; signal cc:STD_LOGIC_VECTOR(3 downto 1); begin fa0:fulladd port map(x(0),y(0),c,s(0),cc(1)); fa1:fulladd port map(x(1),y(1),cc(1),s(1),cc(2)); fa2:fulladd port map(x(2),y(2),cc(2),s(2),cc(3)); fa3:fulladd port map(x(3),y(3),cc(3),s(3),co); end Behavioral;
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity fulladd is Port ( a : in STD_LOGIC; b : in STD_LOGIC; cin : in STD_LOGIC; sum : out STD_LOGIC; cout : out STD_LOGIC); end fulladd; architecture Behavioral of fulladd is begin sum<=a xor b xor cin; cout<=(a and b) or (b and cin) or (a and cin); end Behavioral;
ERROR:Simulator:170 - work/fulladd/Behavioral is not compiled properly. Please recompile work/fulladd/Behavioral in file "C:/Xilinx91i/ripple/../fulladd/fulladd.vhd" without -incremental option.
ERROR:Simulator:198 - Failed when handling dependencies for module ripplewav
