jagspaul
Junior Member level 2
One question, the ringing tendency is less in case of flyback continuous mode rather than discontinuous mode. Please tell me whether it is correct or not.
Regards
jagspaul
Regards
jagspaul
I think it isn't generally. There are however different kinds of ringing. In discontinuous mode, the transformer main inductance is disconnected after the output current reaches zero. You have a rather high impedance resonance circuit then, that can show a low frequency ringing, but it's meaningless, because the oscillation energy is very low. You have the same phenomenon with a discontinously operated buck converter, by the way.ringing tendency is less in case of flyback continuous mode
