ring generator circuit
Laplace
Full Member level 1
ring generator circuit schematic is required. any help?
Thanks,
Laplace
ring generator schematic
Telephonic Rings is generated by a signal of 50-80 VRms, 25 to 50Hz.
Easy way to do it, is using a AC transformer from line power to your circuit, just let a secundary of your power source with 70 Vrms AC 50Hz.
Ring circuit in most telephones is a .47uF capacitor in series with 4K7 resistor. So, current you need is less than 2mA.
Thanks for your kind help.
At the same time, I am working on generating -48V DC from ~220V AC. Any schematics or suggestions?
Thanks...
Please see the supertex products, they are suggesting ring generator ICs.
Hi
Have a look at that :
h**p://w*w.hotspot.freeserve.co.uk/HOTSPOT/TLS/tlsframe.htm
Schematic is available.
Here is a very simple ringer using 2 transformer & cap
best
bobi :)
