RGMII connection between PHY and MCU
FreshmanNewbie
Advanced Member level 1
I need to make a design with the KSZ9031RNXCC. For mechanical reasons we can’t do this on one PCB, my first idea was to connect the 2 PCB ( max 5cm from each other) with a flat cable. But what is the best approach?
ETH connecter => Flat Cable => KSZ => microcontroller or ETH connecter => KSZ =>Flat Cable => microcontroller
How to design the flat cable for the best signal conditions?
Single ended RGMII interface and clock connections are more ciritical than differential ethernet lines. I would use flat cable on the ethernet side.
