tinkerer73
Member level 3
Hello,
I'm new to the forum, and although I understand all of the basic concepts behind PWM control, and basic circuits using a 555 timer to do this, I'm an absolute beginner when it comes to real circuit designs. I'm trying to educate myself via reading, but I'm looking for help on a specific project that I'm working on at the moment.
I want to backlight a couple of displays with two different channels of RGB LEDs, where they can be set at the desired color(s) and those setting will remain in the controller even with the power removed.
I'm thinking that for simplicity, I'm better off trying to make this with preset mixes of color, and having push buttons to cycle through these, rather than having the RGB mix directly controlled.
I'm looking at using SMD LEDS rather than something like a 5mm superflux, because of space limitations.
Thanks in advance for the help!
