RGB Encoder for TV Test Pattern Generator
Thelux
Junior Member level 2
pattern generator using mc1377p
I'm working on a TV Test Pattern Generator found in:
RGB encoders i'm testing are:
MC1377P (Very bad...)
CXA1645 (Very good but... out of stock)
BH7236AF (Good but... out of stock)
(I have only 1 piece and I'd like to have at least one of supply in breakdown case)
AD724 (good but... without RGB output)
AD725 (the same as 724)
Do you know another RGB+Sync encoder with CVBS, RGB and S-Video Output?
Thanks in advance.
Bye
www.alexm.times.lv/pal_gen.htm
You can use MC13077P I build this work
Regard
preda
