cplia
Member level 2
Some really basic measurement experiment with my MiniVNA Tiny analyzer.
After careful calibration of the VNA, I wanted to check how the input impedance up to 500MHz of a 4m long RG58 cable, terminated on a 50 Ohm dummy load varies. To my surprise I noticed that the SWR response was not flat at all. Actually it was fluctuating so much that I've repeated calibrating my VNA again and checking connectors for short/open circuits etc. Still same response. (response attached on this post). Dummy load is relatively accurate up to 1GHz. When I connect the same dummy load directly to the VNA port the SWR is pretty flat, so obviously something is happening with the cable. But, the cable is brand new, checked for open/shorts as well - all, seemed ok!
Is it really that even minor imperfections along the coaxial cable, the dummy load or the connectors that make the SWR/Zin jump up and down to that extend? I was expecting a flat response at least at the low end of the frequency spectrum.
73,
Kostas
Setup:
|VNA| <-> |4m RG58| <-> |50 Ohm load|
73,
Kostas
Setup:
