OLeoArruda
Newbie
Hello everyone.
I'm having trouble reading MIFARE cards using the MFRC522 module.
I know where the problem is, but I don't know how to fix it.
I am able to communicate with the module via SPI. When I call the function to identify if there is a card, it transmits the 0x26 byte to the antenna and waits to receive a byte from the card. However, she is not receiving anything, even with the card next to the antenna.
attached is the code for a part of the main. I didn't put the configuration pins, because I think everything is ok
attached is the library code:
(the problem is in the MFRC522_ToCard function. After executing the command, it loops, waiting for a bit from the COMMIRQREG register to be set, indicating that a data has been received.
But even with the card, it receives nothing (the loop ends without setting the bit in the register))
I found a post that seems to have the same problem as mine, but has no answer:
C:
MFRC522_Init();
/*--------------- Loop embarcado ---------------*/
while (1)
UART_Write(0x11);
if( MFRC522_isCard( TagType ) ) //This condition never became true
UART_Write(0xCC);
if( MFRC522_ReadCardSerial( &UID ) )
UART_Write(0xAA);
C:
//conecci�n de modulo RFID usando SPI pot software
static void MFRC522_Wr( char addr, char value )
MFRC522_CS = 0;
SPI_Write( ( addr << 1 ) & 0x7E );
SPI_Write( value );
MFRC522_CS = 1;
static uint8_t MFRC522_Rd( char addr )
uint8_t value;
MFRC522_CS = 0;
SPI_Write( (( addr << 1 ) & 0x7E) | 0x80 );
value = SPI_Read();
MFRC522_CS = 1;
return value;
static void MFRC522_Clear_Bit( char addr, char mask )
MFRC522_Wr( addr, MFRC522_Rd( addr ) & (~mask) );
static void MFRC522_Set_Bit( char addr, char mask )
MFRC522_Wr( addr, MFRC522_Rd( addr ) | mask );
void MFRC522_Reset()
MFRC522_Wr( COMMANDREG, PCD_RESETPHASE );
void MFRC522_AntennaOn()
MFRC522_Set_Bit( TXCONTROLREG, 0x03 );
void MFRC522_AntennaOff()
MFRC522_Clear_Bit( TXCONTROLREG, 0x03 );
void MFRC522_Init()
MFRC522_CS_Direction = 0;
MFRC522_Rst_Direction = 0;
MFRC522_CS = 1;
MFRC522_Rst = 1;
MFRC522_Reset();
MFRC522_Wr( TMODEREG, 0x8D ); //Tauto=1; f(Timer) = 6.78MHz/TPreScaler
MFRC522_Wr( TPRESCALERREG, 0x3E ); //TModeReg[3..0] + TPrescalerReg
MFRC522_Wr( TRELOADREGL, 30 );
MFRC522_Wr( TRELOADREGH, 0 );
MFRC522_Wr( RFCFGREG, 0x40 );
MFRC522_Wr( TXAUTOREG, 0x40 );
MFRC522_Wr( MODEREG, 0x3D );
UART_Write(0x99);
MFRC522_AntennaOn();
char MFRC522_ToCard( char command, char *sendData, char sendLen, char *backData, unsigned *backLen )
char _status = MI_ERR;
char irqEn = 0x00;
char waitIRq = 0x00;
char lastBits;
char n;
unsigned i;
switch (command)
case PCD_AUTHENT: //Certification cards close
irqEn = 0x12;
waitIRq = 0x10;
break;
case PCD_TRANSCEIVE: //Transmit FIFO data
irqEn = 0x77;
waitIRq = 0x30;
break;
default:
break;
MFRC522_Wr( COMMIENREG, irqEn | 0x80 );
MFRC522_Clear_Bit( COMMIRQREG, 0x80 );
MFRC522_Set_Bit( FIFOLEVELREG, 0x80 );
MFRC522_Wr( COMMANDREG, PCD_IDLE );
//Writing data to the FIFO
for ( i=0; i < sendLen; i++ )
MFRC522_Wr( FIFODATAREG, sendData[i] );
//Execute the command
MFRC522_Wr( COMMANDREG, command );
if (command == PCD_TRANSCEIVE )
MFRC522_Set_Bit( BITFRAMINGREG, 0x80 ); //StartSend=1,transmission of data starts
//UART_Write(MFRC522_Rd(FIFODATAREG));
//Waiting to receive data to complete
//i according to the clock frequency adjustment, the operator M1 card maximum waiting time 25ms???
i = 0xFFFF;
do
//CommIrqReg[7..0]
//Set1 TxIRq RxIRq IdleIRq HiAlerIRq LoAlertIRq ErrIRq TimerIRq
n = MFRC522_Rd( COMMIRQREG );
i--;
while ( i && !(n & 0x01) && !( n & waitIRq ) );
MFRC522_Clear_Bit( BITFRAMINGREG, 0x80 ); //StartSend=0
UART_Write(MFRC522_Rd(RXMODEREG));
UART_Write(0x78);
UART_Write(MFRC522_Rd(STATUS2REG));
UART_Write(0x22);
UART_Write(i);
UART_Write(0x33);
UART_Write(n);
if (i != 0)
if (!(MFRC522_Rd(ERRORREG) & 0x1B)) //BufferOvfl Collerr CRCErr ProtecolErr
_status = MI_OK;
if (n & irqEn & 0x01)
_status = MI_NOTAGERR; //??
if (command == PCD_TRANSCEIVE)
n = MFRC522_Rd(FIFOLEVELREG);
lastBits = MFRC522_Rd(CONTROLREG) & 0x07;
if (lastBits)
*backLen = (n - 1) * 8 + lastBits;
else
*backLen = n * 8;
if (n == 0)
n = 1;
if (n > 16)
n = 16;
//Reading the received data in FIFO
for (i = 0; i < n; i++)
backData[i] = MFRC522_Rd(FIFODATAREG);
backData[i] = 0;
else
_status = MI_ERR;
//MFRC522_Set_Bit( CONTROLREG, 0x80 );
//MFRC522_Wr( COMMANDREG, PCD_IDLE );
return _status;
char MFRC522_Request(char reqMode, char *TagType)
char _status;
unsigned backBits; //The received data bits
MFRC522_Wr(BITFRAMINGREG, 0x07); //TxLastBists = BitFramingReg[2..0] ???
TagType[0] = reqMode;
_status = MFRC522_ToCard(PCD_TRANSCEIVE, TagType, 1, TagType, &backBits);
if ((_status != MI_OK) || (backBits != 0x10))
_status = MI_ERR;
return _status;
void MFRC522_CRC(char *dataIn, char length, char *dataOut)
char i, n;
MFRC522_Clear_Bit(DIVIRQREG, 0x04);
MFRC522_Set_Bit(FIFOLEVELREG, 0x80);
//Escreve dados no FIFO
for (i = 0; i < length; i++)
MFRC522_Wr(FIFODATAREG, *dataIn++);
MFRC522_Wr(COMMANDREG, PCD_CALCCRC);
i = 0xFF;
//Espera a finaliza��o do Calculo do CRC
do
n = MFRC522_Rd(DIVIRQREG);
i--;
} while (i && !(n & 0x04)); //CRCIrq = 1
dataOut[0] = MFRC522_Rd(CRCRESULTREGL);
dataOut[1] = MFRC522_Rd(CRCRESULTREGM);
char MFRC522_SelectTag(char *serNum)
char i;
char _status;
char size;
unsigned recvBits;
char buffer[9];
//MFRC522_Clear_Bit( STATUS2REG, 0x08 ); //MFCrypto1On=0
buffer[0] = PICC_SElECTTAG;
buffer[1] = 0x70;
for (i = 2; i < 7; i++)
buffer[i] = *serNum++;
MFRC522_CRC(buffer, 7, &buffer[7]);
_status = MFRC522_ToCard(PCD_TRANSCEIVE, buffer, 9, buffer, &recvBits);
if ((_status == MI_OK) && (recvBits == 0x18))
size = buffer[0];
else
size = 0;
return size;
//hibernation
void MFRC522_Halt()
unsigned unLen;
char buff[4];
buff[0] = PICC_HALT;
buff[1] = 0;
MFRC522_CRC( buff, 2, &buff[2] );
MFRC522_Clear_Bit( STATUS2REG, 0x80 );
MFRC522_ToCard( PCD_TRANSCEIVE, buff, 4, buff, &unLen );
char MFRC522_Auth( char authMode, char BlockAddr, char *Sectorkey, char *serNum )
char _status;
unsigned recvBits;
char i;
char buff[12];
//Verify the command block address + sector + password + card serial number
buff[0] = authMode;
buff[1] = BlockAddr;
for ( i = 2; i < 8; i++ )
buff[i] = Sectorkey[i-2];
for ( i = 8; i < 12; i++ )
buff[i] = serNum[i-8];
_status = MFRC522_ToCard( PCD_AUTHENT, buff, 12, buff, &recvBits );
if ( ( _status != MI_OK ) || !( MFRC522_Rd( STATUS2REG ) & 0x08 ) )
_status = MI_ERR;
return _status;
char MFRC522_Write( char blockAddr, char *writeData )
char _status;
unsigned recvBits;
char i;
char buff[18];
buff[0] = PICC_WRITE;
buff[1] = blockAddr;
_status = MFRC522_ToCard( PCD_TRANSCEIVE, buff, 4, buff, &recvBits );
if ( (_status != MI_OK) || (recvBits != 4) || ( (buff[0] & 0x0F) != 0x0A) )
_status = MI_ERR;
if (_status == MI_OK)
for ( i = 0; i < 16; i++ ) //Data to the FIFO write 16Byte
buff[i] = writeData[i];
MFRC522_CRC( buff, 16, &buff[16] );
_status = MFRC522_ToCard( PCD_TRANSCEIVE, buff, 18, buff, &recvBits );
if ( (_status != MI_OK) || (recvBits != 4) || ( (buff[0] & 0x0F) != 0x0A ) )
_status = MI_ERR;
return _status;
char MFRC522_Read( char blockAddr, char *recvData )
char _status;
unsigned unLen;
recvData[0] = PICC_READ;
recvData[1] = blockAddr;
MFRC522_CRC( recvData, 2, &recvData[2] );
_status = MFRC522_ToCard( PCD_TRANSCEIVE, recvData, 4, recvData, &unLen );
if ( (_status != MI_OK) || (unLen != 0x90) )
_status = MI_ERR;
return _status;
char MFRC522_AntiColl( char *serNum )
char _status;
char i;
char serNumCheck = 0;
unsigned unLen;
MFRC522_Wr( BITFRAMINGREG, 0x00 ); //TxLastBists = BitFramingReg[2..0]
serNum[0] = PICC_ANTICOLL;
serNum[1] = 0x20;
_status = MFRC522_ToCard( PCD_TRANSCEIVE, serNum, 2, serNum, &unLen );
for ( i=0; i < 4; i++ )
serNumCheck ^= serNum[i];
if ( serNumCheck != serNum[4] )
_status = MI_ERR;
return _status;
//0x0044 = Mifare_UltraLight
//0x0004 = Mifare_One (S50)
//0x0002 = Mifare_One (S70)
//0x0008 = Mifare_Pro (X)
//0x0344 = Mifare_DESFire
char MFRC522_isCard( char *TagType )
if (MFRC522_Request( PICC_REQIDL, TagType ) == MI_OK)
return 1;
else
return 0;
char MFRC522_ReadCardSerial( char *str )
char _status;
_status = MFRC522_AntiColl( str );
str[5] = 0;
return 1;
else
return 0;
