RFID tag for communication with u2270b
ravi_p
Member level 1
Member level 1
rfid reader ic
Hi
I am looking for low cost low frequency RFID reader IC.Can anyone suggest me the IC
Thanks
rfid reader schematic
As example Sokymat reader IC, works at 125kHz, supports Read-Only and Read-Write transponders.
rfid schematic
The cheapest I know is Philips HTRC110
avr rfid reader
You can read the topic at
There is also other 13.56MHz products from Philips (for I-Code, ISO15693 and ISO14443) and Melexis (a chip very similar to S6700 from TI).
Hope it helps,
bye wn.
rfid schematics
Hello,
Try U2270B - works great and is very reliable. I used it in many my projects and I never had problems. If you play with the schematic you can get reliable reading from 25 cm (it's my own experience).
Best regards
Luben
rfid circuit schematic
Could you post the schematics HERE ???
I would like to build it too.
I use ID-12, 125kHz readers, from www.elatec.de.
cy8c0104
Hello,
here I'm putting one of my projects - door lock system. You can find here everything - schematic, sources and HEX. I guarantee that HEX is working and is tested on over more then 100 successfully sold devices.
The first card that you approach after the chip is programmed becomes MASTER card. When you approach master card, the chip runs in LEARN mode - if you approach other cards and they don't exists in the memory - they are added, if they exists - removed.
The chip supports 24 cards and one master card. Can control door (with motors and magnets). Works really fine and I'm proud with this project.
best regards
Luben
Reactions: gybar
    gybar
rfid card reader schematic
luben111:
thanks for the codes,please upload the sch of it plz.
schematic rfid
Hello,
Actually inside the ZIP file is the schematic in ORCAD format (DSN), but to make it more convenient here I'm uploading it in PDF format. I even made some designs, where the coil is on the PCB, but I got that for sure is better to use external coil.
Actually to increase the sensitivity you have slightly to modify the schematic - just open the U2270 data sheet and copy the schematic around the coil... as I remember there were 4 diodes.
What I remember is that the coil is 68 turns 0.2 mm wire on diameter 60mm. To get the maximum range you should carefully adjust the frequency exactly on 125 KHz... I'm sorry it's been so long time ago and I forgot everything...
And to erase all cards in the memory you need to hold the master card in the coil field ~2 minutes (in case that a card is lost or stolen) - after then you should enter the cards again (master card is NEVER erased).
best regards
Luben
Reactions: gybar
    gybar
long range reader u2270
Cypress CY8C0104/05 chip/module is the new competitor of u2270b. It has many addtional features such as automatic decoding and programmability.And it is the cheapest one in the market.
www.sonmicro.com
schematic for rfid
Salam,
in my work, we use U2270B (SO16 package) to design our wiegand reader :)
Bye
id2 antenna rfid
one question, can an RFID IC made by one company corresponds to transponder ICs made by different companies? is this possible?
u3280 schematic
Better than the U2270 is the ID2. Try a google search.
rfid reader ic circuit
Hello Mr. Georg,
What are the prices of those readers and what kind of reader is that one that requires an OpAmp? Do you have some schematics?
I have contacted you via email.
Muris Trax
schematics for an rfid reader
Luben111, thanks for the u2270 example!
Does the u2270 output manchester code at its output pin?
How many bits does the u2270 output to identify a tag one time? I will convert the output signals into wiegand code. It will be easier if the output is a 3*8bit signal one time.
id12 rfid reader examples
Hi Can you also post the circuit for the Card?
Thanks
sokymat reader ic
hi,
you can look for u2270b from temic or htrc110 from philips
