anjalina
Newbie
Hello Sir/ Ma'am,
Currently we are using 433.92 MHz RF frequency, with the covering of rubber sleeve(Heat shrinkable) on the transmitter device. For reference please go through below link:
We are expecting our range of 12 to 15 meter between TX and Rx, but we get the range of 6 to 7 m by using current sleeve. So please suggest the best sleeve material to get appropriate range according to our requirements.
Note: The sleeve material should be heat shrinkable with less diameter(about 28 mm) , thickness should be less than 0.5 mm, black colour sleeve without glossy look.
