RF transmitter problem
areeckal
Member level 2
Member level 2
I did some code in mplab using hitech compiler for RF transmission.
When i am simulating in mplab i am getting correct output in uart I/O tab. But iam not obtaining any value in the portC ie, TX pin. I tried simulating in proteus by connecting an led to the RC. But nothing is coming. Is there any problem with my code? How to simulate it correctly?
Tx.c
#include <htc.h>
#include "usart.h"
//Chip Settings
__CONFIG(1,0x0200);
__CONFIG(2,0X1E1F);
__CONFIG(3,0X8100);
__CONFIG(4,0X00C1);
__CONFIG(5,0XC00F);
void main()
	int addr=0, data=1,checksum;
	//Initialize the USART
	USARTInit();
	char sendData[5];
    sendData[0]='J';
    sendData[1]='S';
	sendData[2]='0';
	sendData[3]='1';
	sendData[4]=sendData[2]+sendData[3];
	//Transmit Data
	while(1)
		USARTWriteByte(sendData[0]);
		//_delay(100);
		//Send synchronization Byte
		USARTWriteByte(sendData[1]);
		//_delay(100);
		//AddressByte
		USARTWriteByte(sendData[2]);
		//_delay(100);
		//Data byte for start time
		USARTWriteByte(sendData[3]);
		//_delay(100);
		//Checksum
		//checksum=addr+data;
		USARTWriteByte(sendData[4]);
	//	TXEN=0;
		//_delay(100);
usart.c
BAUD RATE:57600 Bits per Second
CRYSTAL Frequency: 20MHz
Target Chip: PIC18F4520
Target Compiler: HI-TECH C For PIC18 (http://www.htsoft.com/)
Project: MPLAP Project File
#include <htc.h>
#include<stdio.h>
#include "usart.h"
void USARTInit()
	//Baud Rate = 57600 Bits per Second
	//*** Note: Valid On 20MHz Crystal ONLY ***
	//For other crystal freq calculate new values for SPBRG
	SPBRG=86;
	//TXSTA REG
	TXEN=1;
	BRGH=0;
	SYNC=0;
	//RCSTA
	SPEN=1;
	CREN=1;	//Enable Receiver (RX)
	//BAUDCON
	BRG16=1;
	//TRISC
	TRISC=0x00;
void USARTWriteByte(char ch)
	//Wait for TXREG Buffer to become available
	while(!TXIF);
	//Write data
	TXREG=ch;
void USARTWriteString(const char *str)
	while((*str)!='\0')
		while(!TXIF);
		//Write data
		TXREG=(*str);
		//Next goto char
		str++;
Writes a line of text to USART and goes to new line
The new line is Windows style CR/LF pair.
This will work on Hyper Terminal Only NOT on Linux
void USARTWriteLine(const char *ln)
	USARTWriteString(ln);
	USARTWriteString("\r\n");
void USARTWriteInt(int val,unsigned char field_length)
	if(val<0)
		USARTWriteByte('-');	//Write '-' sign for negative numbers.
		val=(val*(-1));				//Make it positive.
	//Convert Number To String and pump over Tx Channel.
	char str[5]={0,0,0,0,0};
	int i=4,j=0;
	while(val)
		str[i]=val%10;
		val=val/10;
		i--;
	if(field_length>5)
		while(str[j]==0) j++;
	else
		j=5-field_length;
	for(i=j;i<5;i++)
		USARTWriteByte(str[i]);
unsigned char USARTReadByte()
	while(!RCIF);	//Wait for a byte
	return RCREG;
Help pls
