rf transmission problem
shirishb
Newbie level 5
Newbie level 5
Hi i have a problem i m using 2 ht12e with diffrent addresses n trying to get these data with two diffrent ht12d with respective addresses n i am using monopole as antenna but it is nt working... Can you tell me why it is happening n solution for it
you can't transmit with two transmitters at the same time to two receivers unless they both have separate receiving aerials. You can share a common transmit aerial providing only one transmitter is active at a time.
Frank
Is it not possible with diff addresses also whtvis meant by aerial...
First try to get one ht12e to communicate with one ht12d to make sure is isn't an interference problem. In any case, standard debugging would say that if a complex system does not work, try to make the system simpler and see if it you can get that working. If you can't get the simpler system working, there is no chance you will get the more complicated system working.
aerial = antenna
Are you using an RF transmitter and RF receiver? You can't just connect ht12d and ht12e directly to the antennas and expect them to transmit/receive anything.
