Jester
Full Member level 6
![Full Member level 6](/styles/images/ranks/flevel3.gif)
Does anyone have any insight or suggestions on how to connect ground to the metallic shield (spray on style that is applied to inside of plastic enclosures to help with radiated emissions)
The circuit should be fairly benign because it's low power and low frequency (fundamental noise will be under 150kHz). I expect the cable will be more problematic.
Thank you.
