RF reciever transmitter sample?
tomovill
Junior Member level 3
Hungary
I need RF reciever, transmitter modules free sample.
Have anyone a good link?
HI I GOT ALL WHAT YOU NEED !
texas instruments has a transceiver
TRF6900 you ca request up to 3 samples from their web site
Melexis has a new trasceiver ..the TH7120
you can call them and request samples too !
also toshiba has a new 2.4 ghz trasceiver
Microchip has also free samples from their website
but they are not one chip trasceivers .check the RF section!
Hi tomovill
another supplier of such chips is RFMD. Normally their local distributor ships also samples.
What are the spec's you need?
Bye
I want to make a remote controller for a robot.
I need no chips, i need modules, with an input, an antenna output and a power supply input.
But many thanks for the help.
You won't be able to get MODULES ..
unless you can pretent to a manufacturer . that you have an incredible
potential for your product!
The other solution is to use MICREL RF solutions
To implement a TRANSMITTER or a RECEIVER . you don't need
much !
ALso they may provide you with an evaluation board for free!
They did it with me !.. But you have to talk to their support people
after getting the contact through your local REP!.
otherwise get board form DIGIKEY .. or RADIOSHACK.COM
good luck!
