jportero
Newbie level 3
Hello,
I have some questions about RF communication between two antennas inside a concrete or metallic storage silo. I would like to know the influence of walls and edges of the closed chamber (a cylindrical silo) in the RF signal.
Chamber's walls are connected to ground, and I have some antennas around two fixed vertical axis inside the chamber that transmit and receive at 868 MHz. Its position does not changes.
I know the power loss [attenuation in dB/m] in air and grain environments, and with that data theorically I can know the level of fill of the silo. But the rebounding signal can
What factors I have to consider that could affect communication? Like rebounding, walls absorption, etc..
Thank you,
Javier
Thank you,
Javier
