smith_suez
Member level 3
![Member level 3](/styles/images/ranks/dlevel3.gif)
Hi ,
I am using bluetooth module(F2M03AC2 from FREE2MOVE)in my project.In the datasheet they have suggested to connect directly all the GND Pads to flooded GND plane.ALso if more than one GND is used make a connection between them using as many as vias.
In the layer stack up i have GND Plane below the TOP Layer were the module is mounted.
My question is ,will there be any issues when i connect directly the GND of Bluetooth module to the GND plane below to which rest of the circuit GND is connected.Will there be performance/EMI/SI issue in the rest of the circuit/ Bluettoth module...Please help
