zachi
Newbie level 6
bf199 amplifier
Hi ...
I want to build a 30 dB RF amplifier for VHF range (from -40dBm to -10dBm), so I use two stages of 15dB CE transistor amplifier(BF199) .
Every stage work great @ 200MHz , but when I connect them together..the signal is distorted !!!!!!!!
I try to connect many capacitors (1p - 1mm) between them, but I get the same results.
If I connect them, and check @ 50 MHz - they work great and I get more then 30 dB gain.
what is the best way to solve this issue :?:
Thanks in advance,
Hi ...
Thanks in advance,
