Layout inductance on Q3 even in 100 nano henries will create a flyback spike of twice the switched Vce on the collector of Q3 upper part of half-bridge from "circled" diode anode D3. To prevent Q1 damage this must be suppressed.Hi,
Do you know why the ringed diode would ever need to be 400V rated? Its a general purpose, SMA, 400V diode.
Why ever do you think they used such a high voltage part?
LTspice and PNG attached.
You missed the only overvoltage mentioned in my previous comment Veb =? 10V with 100 nH on Q3C to diode.Thanks, also i was thinking of RC snubbing D3, but theres 8 of these circuits on the PCB and adding 16 new components isnt going to be popular.
As such, we are thinking of just making D3 a 27V zener, but wonder how quickly they "reverse recover" and start blocking? Are BZX84- type zeners just like gen purpose diodes when in the forward direction is concerned?
Its interesting because you can stuff stray L's all over the circuit in LTspice and it never shows any overvoltage to any component.
Though the use of a 27V Zener for the blocking diode seems like a good plan. (as attached).
Any thoughts appreciated?
Thanks, the D3 is needed in case someone puts a voltage source at the load.With resistive load, I don't even see the purpose of D3. Can you enlighten me?
Thanks, sorry i put a stray L on Q3C to diode, but saw no overvoltage on Q1...as attached LTspice and PNGYou missed the only overvoltage mentioned in my previous comment Veb =? 10V with 100 nH on Q3C to diode.
