Reverse iterator for a list (C++)
rogger123
Full Member level 1
I have a problem compiling the following piece of code using reverse itretor for a list.
#include <iostream>
#include <list>
using namespace std;
// Display elements in reverse order
template <class T>
void displayListRev(const list<T> &lst)
list<T>::reverse_iterator rl;
for(rl = lst.rbegin(); rl < lst.rend(); ++rl)
cout << *rl << ' ';
cout << endl;
int main()
list<int> listType;
listType.push_back(10);
listType.push_back(30);
listType.sort();
cout << "List contents in reverse order: ";
displayListRev(listType);
return 0;
it gives me errors for the "for" loop. one of the error is pasted below:
"binary '=' : no operator defined which takes a right-hand operand of type 'class std::reverse_bidirectional_iterator<class std::list<int,class std::allocator<int> >::const"
If I get rid of the function 'displayListRev(listType)' and instead add the correcponding function code within the main function, the error gets resolved and correct output is generated.
Can someone explain the reason for this behaviour.
The modified code is as shown below:
#include <iostream>
#include <list>
int main()
list<int> listType;
list<int>::reverse_iterator rl;
listType.push_back(50);
listType.sort();
for(rl = listType.rbegin(); rl != listType.rend(); ++rl)
cout << *rl << ' ';
return 0;
regards
rogger123
If you look closely at the definition of your function
template <class T>
You have declared the parameter lst of type const.
Therefore to iterate over the list you must use one
of the const iterators, i.e.
list<T>::const_reverse_iterator rl;
This should fix your compiler warning about not being able
to do the assignment.
Alpha
    rogger123
thanks for the solution...as you said, it was the 'const' that was creating the problem.
