Reverse Current Surges
P
ParkerMike
Newbie level 1
When does a circuit produce reverse current surges? When it's switching off and on? or when switching from a Positive cycle to a negative cycle?
Reverse current surges will cause damage to capacitors and transistors
I think you are talking about the energy stored in the magnetic field of an inductor. When the current is cut or reduced, the inductor produces back EMF (= Di/Dt X L), this is in the opposite direction to the the original voltage that charged the inductor.
Frank
