resistor in near probe fed
sahar20
Member level 1
Member level 1
i want use from resistor in the near probe fed to patch but i dont know. please helped to me so that i use from resistor. Thanks
You can add lumped elements to a stucture on Modua and simulate the resulting system. In Mgrid/IE3D, you can define ports at the place where lumped elements are to be connected. Do EM simulation with the defined ports but without lumped elements and then connect the lumped elements to the ports and simulate the system on Modua.
    sahar20
