fred3991
Member level 1
Hey, everybody,
I am trying to make a Wilkinson power divider 1-to-2. on a PCB using CPWG transmission lines. The frequency is 13 GHz. (Er 3.48, thickness 168 um)
I have built a model on using these components. (and using the multistage wilkinson power divider calculation from Microwave101).
And I am completely satisfied with the results.
However, when creating the layout I don't know how to properly place/take into account the influence of SMD resistor contact pad. For SMD size 0603 - (1.6x0.8 mm ) I need pads about 0.8x0.8.
When I did a simulation without considering these pads in the EM simulation - the results are more or less OK, (Yes, this is 1 stage only, i just tried to figure out what is the problem on smth simple )
But if I put a 0.8x0.8 pad (Or something similar) the results are terrible. (Transmission lines 100 and 200 um)
How to take into account the size of these pads, so that they minimally affect the performance of power divider?
Maybe I should choose a thicker dielectric substrate so that my lambda/4 lines are the same size as this resistor pad?
Maybe a tapper should be used?
