jmx66
Member level 5
Hi all,
I only want to know, right power value for gate resistor of igbt module.
igbt module : infineon FS50R12W2T4 from datasheet rg on about 15 Ohm.
MEA1D1509SC pin 6 Vcc 9V
pin 4 Vee -9V
From p5 FOD3120 datasheet
Ioh High level output current Vo = Vcc - 3V so 6v -- 9V = 15V
Vo = Vcc - 6V so 3V -- 9V = 12 V
I is about 2A but for Vcc=30 V with 18V how to compute right values?
Iol Low level output current Vo = Vee + 3 V = - 6 V so -6 -- 9V = 3 V
Vo = Vee + 6 V = - 3 V so -3 -- 9V = 6 v
I]I is about 2A but for Vcc=30 V[/I] with 18 V how to compute right values?
Idem if i watch, p7 FOD3120 datasheet:
Fig 5 Output low voltage / output low current
1° Vcc = 15 > 30 V
I'd like to know maths, for R1 and R3 power values.
Thanks a lot.
jm
pin 4 Vee -9V
1° Vcc = 15 > 30 V
Thanks a lot.
jm
