Resistive CMFB circuit question - capacitors
fcfusion
Full Member level 4
Full Member level 4
Hi everyone
I have a simple question about resisitive CMFB circuits. I often see in literature two capacitors in parallel with the CMFB resistors. What's their function?
Thanks
ideal_CMFB_circuit.png I think it's either
  • to speed up the CMFB control after fast changes
  • or it's actually a capacitive CMFB coupling, the resistors providing initial states and preventing unusual potential - just for simulation purpose; not necessary in real silicon.
I'm aware of only your first suggestion, especially if it's a continous time circuit.
Two resistors across the output will require a current if the differential output is nonzero, and, in an OTA, they will lower the voltage gain; therefore, they're typically taken as large as possible. The large R, combined with the input capacitance of the commom-mode amplifier (typically a gate capacitance), adds a pole to the CMFB loop. Adding a capacitor across the large R introduces a zero that can be used to prevent instability / have higher ugbw (= speed up). At high frequencies the transfer from circuit outputs to CM amp gate is just a capacitive divider now..
Hope this helps,
