Lorenz.zulu
Newbie level 3
Hi everybody!
Trying to fix some problems concerning the main fan of a laptop, I was advised to reset the BIOS. I knew that normally disconnecting the BIOS battery is sufficient to do this task, but I was asked to short a couple of pins for 30 seconds with motherboard off, so without Power supply, laptop battery and BIOS battery.
Components to short: JOPEN or capacitors C194 and C195 or diode D27 (Cathode and ground or anode and ground). See the following diagram:
Should I expect with this procedure to reset all the BIOS settings, cancelling even the altered bytes (including data not accessible from the bios menu)?
And should I get this result with a simple screwdriver and with motherboard completely off, without Power supply and batteries connected?
Please, someone tell me something about BIOS resetting techniques.
