Rajinder1268
Full Member level 3
I am using a ft232r usb UART device. I use cbus0 to control the reset line of a supervisory ic @3v3. The supervisory ic also connects to the reset line of a PIC microcontroller. The supervisory device is active low with a push pull output. It is a device from ON semi CAT809JTBI-GT3. I can't seem to pull the supervisory line to 0V to reset the PIC via USB control. It stays at around 2.5V.
I suspect it is because of the push pull circuitry. Can anyone assist.
