yes as you said there is nothing to do with silicon process, since i wanna just see memory behaviours with the delays in an embedded application i wanna create rtl level, so i thought i can use a simle code for ram, i already have it there are so many vhdl code for ram in the internet, but i m not sure about using this one, cos there are two points;
-if i compare rram to sram; rram has long write time.
-sram is volatile, rram is nonvolatile.
so by considering these two features, i am thinking that, i can use the same vhdl code that i use as sram by introducing some delay which i have got from my measurements for write operation, read operation has the same delay as sram already.
surely i know it has nothing to do with silicon, my point is to just simulate to see how much does this delay(for write process) effect the performance of embedded processors, from this point of view i can see that is it applicable or not;
for example this sram code is given, i guess i can use the same model with the delay before write operation
-- a simple 4*4 RAM module (ESD book Chapter 5)
-- KEYWORD: array, concurrent processes, generic, conv_integer--------------------------------------------------------------
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity SRAM is
generic(
width:integer:=4;
depth:integer:=4;
addr:integer:=2
port(
Clock:in std_logic;
Enable:in std_logic;
Read:in std_logic;
Write:in std_logic;
Read_Addr:in std_logic_vector(addr-1 downto 0);
Write_Addr: in std_logic_vector(addr-1 downto 0);
Data_in: in std_logic_vector(width-1 downto 0);
Data_out: out std_logic_vector(width-1 downto 0)
end SRAM;
architecture behav of SRAM is
-- use array to define the bunch of internal temparary signals
type ram_type is array (0 to depth-1) of std_logic_vector(width-1 downto 0);
signal tmp_ram: ram_type;
begin
-- Read Functional Section
process(Clock, Read)begin
if (Clock'event and Clock='1') then
if Enable='1' then
if Read='1' then
-- buildin function conv_integer change the type
-- from std_logic_vector to integer
Data_out <= tmp_ram(conv_integer(Read_Addr));
else
Data_out <= (Data_out'range => 'Z');
end if;
end if;
end if;
end process;
-- Write Functional Section
process(Clock, Write)
begin
if Enable='1' then
if Write='1' then
tmp_ram(conv_integer(Write_Addr)) <= Data_in;
end if;
end if;
end if;
end process;
end behav;
