thunderdantheman
Member level 4
Folks,
Researching the various MIMO radio techniques. With regards to spatial multiplexing where discrete data streams are sent via an individual modulator, transmitter and antenna section on the same frequency and bandwidth, what practical path differences or individual channel delays are required so that the receiver can retrieve/reconstruct the independent channel streams?
Am I correct in assuming that a path difference would have to be such that several phase rotations of the carrier would be required between each receiving antenna to ensure the down converted baseband (or low IF) signals are adequately separated in time for the MIMO transforms to work?
Required multi-path delay for MIMO spatial multiplexing mode of operation - Can't edit the title..
