require suggestions for TV modulation modules
alangeering
Newbie level 2
Newbie level 2
Hello,
Little Hello:
This is my first post here as I've only just found out about EDAboard, it's good to see such a wealth of design knowledge being shared.
Context:
I have a lot of video cameras (pal baseband video output) that are used around a theatre/church/stage for recording action. All are currently connected back to vision mixers by coaxial (RG59) BNC terminated cables. I would like to be able run fewer cables by employing a modulation scheme as is use by over the air TV and running one cable from the last camera in the chain, via the other cameras, to a demodulation box.
Problem:
The part numbers and suppliers for the modulator modules I've seen listed on the internet (even ePanorama) are all out of date and no longer in production.
Detail/Spec of part required:
Module has to be currently in production and available to an amatur/experimenter (i.e. not just 1000 unit sales).
I2C control of frequency choice
RF in and out ports such that they can be chained
Basically, I would like the same module as the ones I can see in my VCR
I don't really care about audio
I hope I've been clear and someone can help me.
Thanks,
Alan G
Hello Alan,
You'll find some simple VCR type modulators on the below web page.
They are in production, and you could buy smaller quantities (I buy usually 100 pcs once. If you need more info about the purchase, contact me by PM)
I also have a similar project you described, so I recomend to take care about the following issues:
-the output frequency range of these modulators is (usually) in the 470-860 MHz range (UHF). There are some low frequency models, but if you want to chain them on a single coax you should use the UHF model.
- the output level is around 70 dBuV and the C/N typically 45 dB , which is acceptable for connection to a TV set with a 1-2 meter long coax cable. But for connecting them with several 10 meters it is not enough. It will degrade your C/N.
So, you should first use an amplifier, and after that connect through a directional coupler to the common coaxial cable (this one should be RG6 at least, due the higher loss at UHF of the RG59).
- if those above looks too complicated, you still can made your own modulator using for example a TDA8822 and a few passive components. You can program the output frequency on I2C.
Best regards,
Al
