linuscomex
Junior Member level 3
electron flow in circuit, when wavelength is very longer than size of circuit ?
1--My first question is: when signal with low frequency such as 100khz the wavelength of that is 5 kikometer that means between high and low voltage must be 5 kilometer .so when signal propagate by electron in short circuite (size of circuit is very small than wavelenght)how does electron flow in circuit and 5 kilometer space between the hight and low voltage produce in short circuit???is it true the wavelength of the signal that means:distance of electron travel to reach the first point? If it is true so the signal with 5 kilometer wave lenght produce complete when electron travel 5 kilometer and thus structure repeat.
2-when the size of circuit very small than if wavelength ghen for analysis the circuit we use Kirchhoff's circuit laws Whay the voltage and current in this circuit not change?but in high frequency change I guess in low frequency that wavelength very big than size of circuit the electron have Enough time to reach end of wire and Enough to produce a cycle of signal Because the electron move is very fast and wavelength is very long that the cgarge of electron Enough time to travel on circuit and produce a cycle of wave before next cycle produced. I guess this 2 reason for not change current in length of wire and voltage in first and end of wire is same.is it true?
I know transmission line theory how work. but I dont undrstand whay voltage and current is same in all of the wire lenght,when frequency low and wavelength is very long of size of circuite? in transmission line and maxwell theory happen stand wave because the wave length in antenna and transmission line is proportional lenght of conductor and electron charge not enough time to reach end of conductor befor a cycle if sine wave ended so the electron charge reflected back and stand wave happen this reason of whay antenna work like resonator and radiate with high amplitude. In transmission line and antenna the voltage and charges electron in 1cm and 3cm of wire length is difference because the frequency is very high and wavelength proportional to size of length wire and when electron charge flow in wire because of wavelength the cgarge if electron difrrent in length of wire and no time to reach end of wire and this reason the voltage in length of wire is difference unlike lumbd circuit that voltage same in all length of wire. I dont undrestand this phenomenon how to happen in low frequency and very long wavelength which makes voltage not changed in lenght of wire? is it true the sentence Thanks bro.
When wavelenght is very long that length of circuit and open clos loop the current is zero because all voltage in length is same and no potential make in circuit .
But when wavelenght is short and length of circuit or electrical length same it in open wire have current.
whay diffrence between this state?
