Hi ganesh ...i AM new for arm processor hw can i learn about it....what book i refer for it......is this processor available in delhi.......pls guide me
thax in advance
As i understood, Finger print module has RS232 port. Which can be connected to your ARM Kit. Command and control instruction have to send on RS232 port by arm processor. Try it... its mot that much difficult.
---------- Post added at 06:20 ---------- Previous post was at 06:14 ----------
Well Ganesh, Don't ask for Code, because nobody will sit and write code for you. If you want to learn, then you should write it.
and after writing if some problem is there which you can not solve then only you should post it....Otherwise....you will not learn even basics..........pls dont mind...but its true
---------- Post added at 06:23 ---------- Previous post was at 06:20 ----------
