[REQ] Signed serial divider in VHDL
cube007
Full Member level 6
Full Member level 6
Australia
serial divider vhdl
Hello,
After searching the forum and using google I’m not very happy with the results. I need a serial synthesizable divider in VHDL. The width of the numerator and denominator should be adjustable separately. The numerator must be a signed value - the dominator not.
Currently I’m using the LPM_DIVIDE IP from Altera but this one is using too much space so a serial divider would be a solution moreover there’s enough time for a serial calculation.
All I found in the web were serial dividers for unsigned values. Isn’t it possible to do a serial calculation with signed values?
Bye,
cube007
