staric
Member level 4
failed to open prop. bag
I import def file generated from sedsm in icfb. But it is failed. The warn message is following.
*WARNING* Failed to open cell view "test aaa layout" in mode "r".
*WARNING* dbOpenBag: Failed to open prop. bag for "test" in "r" mode, file not found.
*WARNING* Unable to find master ND3D0!
*WARNING* Unable to find master ND3D0. Instance U237 not created.
But I have found the cell ND3D0 in the library. And the ND3D0! cell should not be in def file. Why the hint is ND3D0!d.
