REQ: PLL 4046 phase-locked loop 15,625Hz H-Sync to 12.0MHz
ZeRoN
Full Member level 1
pll 4046
I want to use 4046 phase-locked loop IC.
to generate 12.0MHz (for MPU. clock) from 15,625Hz PAL-B Horizontal Sync.
with phase-locked at rising edge.
(to make an OSD.)
Anyone have the circuit?
Regards,
ZeRoN
pll 4046 application
for PAL application, you'd better use TI's TLC2932,
its speed is higher. the operating speed is:
5V Lock Frequency x1 Output(MHz) 22 to 50
5V Lock Frequency x1/2 Output(MHz) 11 to 25
for detailed application information with
TLC2932,
https://focus.ti.com/docs/apps/catalog/resources/appnoteabstract.jhtml?abstractName=slaa011b
best regards
(to make an OSD.)
Regards,
ZeRoN
Added after 3 minutes:
74HC4046 is not as good as TI's TLC2932 and TLC2933,
if you decide to use 74HC4046,
the attched file has many useful information
with 74HC4046.
best regards
(to make an OSD.)
Regards,
ZeRoN
Added after 4 minutes:
but if you have no choice, you can refer the
attached file, there are many useful application
with 74HC4046.
best regards
(to make an OSD.)
Regards,
ZeRoN
