[REQ] Lossless data (de)compress algorithithm (C/VHDL)
cube007
Full Member level 6
Full Member level 6
Australia
Hello,
For transferring data from a PC to an embedded System via Ethernet (UDP packets) I’m looking for a fast and efficient lossless data (de)compress algorithm in C and/or VHDL. At the moment I’m sending UDP frames with about 22kBytes from the PC to the embedded hardware. With a standard LZH (Lempel-Ziv-Huffman) algorithm the frames can be compressed down to 40%. The current implementation is derived from **broken link removed**. But the code is too slow.
Any recommendations are welcome.
Regards,
cube007
dear cube007,
i don't recall any ready-to-use core for solely such thing. However, you might want to have a look at hardware JPEG encoder core at opencores. Huffmann encoding/decoding is part of both JPEG and MPEG.
A suggestion is to use RLE (run-length encoding) followed by Huffmann. Both are found as part of JPEG IPs.
Plus: There floats around the web an old (i think incomplete by a file or two) university project of some course named EE552. They did a lossless data coprocessor of some sort.
best regards mate
the_penetrator©
Hello the_penetrator,
Thank you for your contribution. Using some stuff of JPEG is a good idea. There are lot of information about JPEG in web. I will check this.
After doing some more activities to find something useful in the web I come across to https://www.oberhumer.com/. LZO Algorithm seems to be a good alternative for fast compression and decompression.
Bye,
cube007
