req => info about : coil design on pcb layers
incognito
Member level 2
Member level 2
pcb coil
looking at websites, books references, eventually software information not in priority...
Thanks!
Rgds.
pcb coil design
You will like this attachment :wink:
    V
pcb coils design
thhhhanks!
here is a 50 points reward :lol:
coil pcb
How can protel?
pcb printed rf coils
myasar said:
How can P*otel?
protel :)
I advice u u read a bit this document. With protel only, it might be hard... :)
And I heard that this "method" need several prototypes and component implementaton can cause difference as well.
Like I've seen something on the inet :
I really doubts about efficience of a pcb coil at any VHF frequency... I would like to hear if some guys here already used this technique in a real project. Were the results as expected, incoherance from simulation to real prototype and things like that
Have fun !
pcb inductor design
Some time ago I was searching solution for same problem and I found very old program from Agilent called APPCAD. It contains tool for spiral coils design. Surprisingly 3-pole filter with coils designed by this program works better than expected, on first try and no addidtional tunning needed. Try search for this program in forum, I think I seen it somewhere, but it must be old DOS version.
spiral coil pcb
HMX said:
Some time ago I was searching solution for same problem and I found very old program from @gilent called APPCAD. It contains tool for spiral coils design. Surprisingly 3-pole filter with coils designed by this program works better than expected, on first try and no addidtional tunning needed. Try search for this program in forum, I think I seen it somewhere, but it must be old DOS version.
Where Can I get that program ?? PPCAD? Does it have tutorial for it ?
I need information about it please,
Thanks in advance,
AHmad,
inductance coil pcb
I built a kit of a VHF oscillator at ~100MHZ
If the circuit board was a few mm above a sheet of metal it stopped oscillating. Putting my hand above the circuit board give a frequency shift.
pcb coil for vhf
Of course the frequency will change. The inductance of the PWB inductor is affected by nearby metallic objects. At first it seems nice to use printed inductors, but the properties of the circuit board changes with batches (material, process variations). FR-4 material is not the best for RF if reasonably high Q-values is needed. Then it is also quite difficult to tune a resonance circuit if the inductance needs to be changed. Furthermore, a chip type inductor is indeed smaller.
pcb coils
someone showme this
