req:avanti astro environmental varible path
aravind
Advanced Member level 1
india
can anyone pls give the path for astro(synopsys) 2003.04 .
thanks
Hi, there is no fix path for Astro. The path is where the placed you install the software. If I am not mistaken, there is no installation needed for astro 2003.04. You just need to untar the tar ball. If that is the case, then your path will be the place where you untar it, with "\bin" or "\bin\hp.32" or something like that at the end, where you can find the binary for astro. Hope this will help.
It depends on where you install the astro to.
