[SOLVED] report_delay_calculation problem
ajhunt18
Member level 1
Member level 1
I have discovered this report_delay_calculation command in Design Compiler (DC), but having problems implementing it. I have attached a screenshot of the error report in DC.
Anyone, please help. Thank you!
did you try get_net for it ?
1. get_net fine_out[0] --> to make sure DC know this net, this net exist
2. if 1 ok, use ".... -to [get_object_name [get_net fine_out[0]]]"
Okay, thank you. I'll do that.
By the way, what will be the command if I am to calculate the delay of a 2-input nand gate? what should I put in the "-from" portion? :???:
