- Joined
- Aug 2, 2011
- Messages
- 1,163
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,316
- Activity points
- 22,318
Schema was improved by a transmitter. The transformer used had 160VA, tension of 2x12,5V under rated load current.
Few elements like indicators and the housing KM 85 were added.
Also a plate was made:
The plate was printed and digested by laser printed, iron and chloride.
Few photos from production.
Two last photos is a well known way of accurate drawing size and points for drilling the holes on the plate. It helps to save the time and improves performance. It was printed on an ordinary sheet (also designed in EAGLE, to stick adhesive foil with descriptions. Dimensions should be accurately applied, which is easy and fast in EAGLE).
And some possibilities of power supply:
Stress tests:
Drawing of front plate with applied points of drilling and edges of holes:
And the front plate in a printer version:
The plate:
Improved version of the print – ready to be printed:
Distribution of elements (dashed lines indicate bridges):
Link to original thread – Powtórka z Historii, czyli zasilacz dyskretny. Odsłona II
