tnnedaboard
Member level 3
I am a programmer, and recently I'm passionate electronics ...
I had a problem (dead) with the microprocessor circuit following ...
I'm venturing to replace the microprocessor, and thus to remake the software, since I know the signals generated.
I wanted to know if the signals on the transformer T1 must have a synchronism between them ...
I came to this, because if I unlink, for example, the signal on pin C of T1, I have an output signal of TP6, and if you remain connected (as it should be) I have no signal, and the MOSFET Q2 (IRF4905) is heating may be significant ...
