Replace an AT89C2051 with AT89S2051
red_thunder
Newbie level 3
Newbie level 3
at89s2051 programmer
Hi!
If anyone could help, I would like to know if I could replace an AT89C2051 with AT89S2051 without any modification in hardware and software.
Let me explain, I have an project of ELEKTOR (IR light dimmer) based on the C2051 uC that cannot be programmed through the ICSP programmer that I already have, so I would like to replace it with S2051 uC if it is possible.
THANKS !
Andrej
at89s2051
Hi
Yes you can replace s2051...
Take care of serial programming lines if you decide to program it in the board
Regards
Nandhu
at89s2051 isp
it can be done if you have any douts check atmel website for any application notes for migrating from 89c2051 to 89s2051
at89s2051 project
just replace...
there is no difference..
89s51 is very same as 89c51 in everything..
Also, AT89C2051 and AT89S2051 are also very same..
One small difference..:
89s51 has one small facility.. it can be both programmed with ..
1. a programmer..
2. serially ( ISP)
Regards,
Simran..
difference between at89s2051 and at89c2051
i did it before and there was no problem at all
at89s2051 isp programmer circuit
u can replace s series by c series without modifying in hardware .in fact s series is same c series just we can program s series with isp.
at89s2051 problem
Hi!
I would like to thanks for all your answers.
I have only one another question. Could I attach my USB ISP programmer (it support AT89S2051) direct to the MOSI, MISO, SCK, RST, VCC and GND port of the uC or I must add between some resistors, on my hardware, becouse I have never designed an uC with ISP programming capability.
Thanks for all your answers.
Andrej
at89c2051 application notes
Hi
connect directly to port pins dont use any resistors.
It may cause problems
The circuit will help me to guide you better
Nandhu
difference between atmel 89c2051 and 89s2051
Thanks for your help, Nandhu
I have attached the circuit diagram to understand better what I have to do.
Thanks
Andrej
dimmer at89c2051 elektor
no probs at all....it will work
burning circuit for 2051
Hai Red_thuner
Thanks for your credits..
Shall i know whether you are able to program incircuit??
My advice : Please shift all the inputs or outputs connected to isp pins to someother free pins (I can see lot of free pins).
nothing else
Regards
Nandhu
serial isp programmer for at89s2051
My experience with this ISP stuff is, the reset pin must not connect to the other components while the ISP do its 'burning', so you may have a jumper when the circuit is in downloading process and when the circuit is running its program
at89c2051 prog india
hi
they both are nearly same with little small difference, but it will work in your project, I used it no problem came.
regards
