Renovated oil compressor
It is a project of renovation of an old oil compressor. Protection, compressor, decanter, pressure swtich, regulator etc were attached to the cylinder.
Rings of the compressor were changed to new ones, the same with oil, pressure regulator and seals. Check if thermal switch has the right protection for used motor. Return valve allows to restart the motor at loaded cylinder when the pressure switch is on.
What you need for this project:
  • chlorinated rubber paint
  • seals
  • teflon
  • nipples
  • reducers
  • couplings
  • pressure regulator with filter
  • motor switch
  • rings for the compressor
  • return valve
Pictures of the oil compressor before renovation:
**broken link removed****broken link removed****broken link removed**
And after renovation:
**broken link removed****broken link removed****broken link removed****broken link removed**
Link to original thread (useful attachment) – Nowe życie kompresora olejowego
