Renesas M16C R8C FoUSB/UART Emulator Debugger
budhy
Advanced Member level 3
Indonesia
fousb/uart
Any information about Renesas M16C R8C FoUSB/UART Emulator Debugger?
Could M16C R8C FoUSB/UART Emulator Debugger replace KD30?
M16C R8C FoUSB/UART Debugger User's Manual
emulator for r8c
Yes it could. The KD30 works over an asynchronous interface and can only use adress match interrupts.
The E8 emulator works over an synchronous interface and can use adress match interrupts and can insert breaks in your asm code to use more interrups.
Gomez
uart debugger
@Gomez:
What kind of renesas project(s) you conducted?
fousb uart
Do ou try E10A Emulator? This emulator is much more better.
Try search it at Renesas Web Site.
I do not use E10 Emulator, but I use E8 and also FoUSB.
However KD30 is a handy tools, and now FoUSB/UART Debugger replace KD30.
which emulator supports real time debugging for R8C tiny microcontrollers?
We are trying with E8 emulator and found that it is not working in real time. So some interrupts are missing due to emulator.
NKG
