Remove unwanted via & traces in Altium
R
rammu
Newbie level 1
How to find/remove the unwanted traces (Dangling lines) & vias in Altium? Thanks.
If you use Ctrl+H during routing it will select all the copper connected that trace and you can delete it all.
Set the Net Antennae rools in Manufacturing section in design rules. This is set as 0mm by default. Run Tools->Design rule Check which shows unconnected tracks or vias in Net Antennae section of the report.
We cannot completely rely on this always as i have seen this feature not working properly in some cases.
While routing, always try to route with the option 'automatically remove loops' enabled. This reduces the chances of such errors.
