Bengt
Junior Member level 1
remove the dc level
I need to remove the DC offset of a signal that consist of small pulses as a result of sampling. The problem is that the circuit must be very accurate as the resulting signal shall be amplified several undered of times afterwards and that the circuit must be very small as there are very limitid space.
I have done it using feedback from a microcontroller and a DA but the resolution is a problem and an anlog solution might be to prefere. I fugured to use a peak detector and remove the top that way but I have accuracy problem.
