Hickey801
Newbie
I'm looking to build a remote-controlled Free/Busy light that will toggle between the two lights when a button on the remote control is pressed.
I've considered using a proprietary remote controlled mains light switch, but see two issues with that. 1) This would presumably be powered by stepped-down mains voltage and I want to have a purely battery-powered unit. 2) It would also only switch one light on and off, rather than toggle between the two.
I have found suggestions online for circuits using transistors to toggle the power between two lights, which would seem to address the second problem. Another solution might be a relay, but then I run into the issues of higher voltage required, reduced battery life, mechanical wear/failure etc.
Any suggestions, whether circuits for both remote control and switching, or a solution using a proprietary remote controller and receiver then connected to a custom-built switching circuit, would be most welcome.
Many thanks,
J
Many thanks,
J
