Relay selection advices needed
bbkv_tom
Relay selection
I need to provide a NC relay on a 24VAC line which goes to a contactor coil.The max current through the line is 2A. The inrush current is aroung 10-15A. Do i need to use a relay that has contact that can carry greater than 15A or the max continous current of 2A..
Please provide your suggestion
Thanks
Relay selection
Generally in a relay, the inrush current is termed as switching current and you can look for both the parameters in the datasheet. But look for higher current than the actual operating current.
Re: Relay selection
bbkv_tom said:
I need to provide a NC relay on a 24VAC line which goes to a contactor coil.The max current through the line is 2A. The inrush current is aroung 10-15A. Do i need to use a relay that has contact that can carry greater than 15A or the max continous current of 2A..Please provide your suggestion
Thanks
Does your contactor relay really draw 2A? :idea: The inrush current may be handled by the contactor...so why bother about that part? Cheers
Probably should get a safety factor on 2A, but most datasheets have a max repetitive surge current or something along those lines
