relay driver using uln2803 to switch on the lamp
BISH
Junior Member level 2
hi all,
i want "a relay driver circuit using uln2803 to switch on the lamp" in proteus
Connect input drive signal to ULN2803 input pin. Connect lamp between the corresponding output pin and +V. Connect pin 10 (COM) to +V. In Proteus, the common emitter pin of ULN2803 is hidden and is connected to ground.
By the way, for driving a single lamp, you can just use a transistor. You don't need to use ULN2803.
Hope this helps.
Tahmid.
Reactions: BISH
    BISH
by replace light instead of motor......
Reactions: BISH
    BISH
